Saltar al contenido principal
Lenovo ThinkPad T470S Fan and Heat Sink Replacement
Qué necesitas
  1. Lenovo ThinkPad T470S Fan and Heat Sink Replacement, Bottom Panel: paso 1, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470S Fan and Heat Sink Replacement, Fan and Heat Sink: paso 2, imagen 1 de 1
    • Loosen the four screws from the heatsink with a Phillips #000 screwdriver.
  3. Lenovo ThinkPad T470S Fan and Heat Sink Replacement: paso 3, imagen 1 de 1
    • Unplug the fan from the motherboard.
  4. Lenovo ThinkPad T470S Fan and Heat Sink Replacement: paso 4, imagen 1 de 1
    • Remove the heatsink and fan from the laptop.
  5. Lenovo ThinkPad T470S Fan and Heat Sink Replacement: paso 5, imagen 1 de 1
    • Wipe off the old thermal paste with either 99% isopropyl alcohol or kimwipes.
  6. Lenovo ThinkPad T470S Fan and Heat Sink Replacement: paso 6, imagen 1 de 2 Lenovo ThinkPad T470S Fan and Heat Sink Replacement: paso 6, imagen 2 de 2
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 81
Todo El Tiempo: 1,952
