Saltar al contenido principal
Lenovo ThinkPad T460s Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Wi-Fi Card Replacement: paso 2, imagen 1 de 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Wi-Fi Card Replacement: paso 3, imagen 1 de 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Wi-Fi Card Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: paso 4, imagen 3 de 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: paso 5, imagen 1 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: paso 5, imagen 2 de 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: paso 5, imagen 3 de 3
    • Disconnect the gray and black cables from the Wi-Fi card.
    • Remove the 3mm Phillips #1 screw on the chip.
    • Remove the Wi-Fi card from the device.
Conclusión
2 personas más completaron esta guía.
2 comentarios
which replacement modules would you recommend? I am looking for alternatives to the 8260 that seems to be flawed.
albert einstein - Contestar
I have now replaced my Wifi-Card and just wanted to point that you instructions diverge from the official ones suggested by Lenovo. This manual simply recommends to deactivate the internal batteries through a bios option - which seems easier than the instructions laid out here.
still, cheers for your guide.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 43
Todo El Tiempo: 3,118
