Saltar al contenido principal
Lenovo ThinkPad T440p Wireless Adapter Replacement
Qué necesitas
  1. Lenovo ThinkPad T440p Wireless Adapter Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Wireless Adapter Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad T440p Wireless Adapter Replacement: paso 2, imagen 2 de 2
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Wireless Adapter Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T440p Wireless Adapter Replacement: paso 3, imagen 2 de 2
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Wireless Adapter Replacement, Back Cover: paso 4, imagen 1 de 2 Lenovo ThinkPad T440p Wireless Adapter Replacement, Back Cover: paso 4, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
  5. Lenovo ThinkPad T440p Wireless Adapter Replacement: paso 5, imagen 1 de 1
    • Slide down the back cover.
  6. Lenovo ThinkPad T440p Wireless Adapter Replacement: paso 6, imagen 1 de 1
    • Remove the back cover.
  7. Lenovo ThinkPad T440p Wireless Adapter Replacement, Wireless Adapter: paso 7, imagen 1 de 2 Lenovo ThinkPad T440p Wireless Adapter Replacement, Wireless Adapter: paso 7, imagen 2 de 2
    • Use the spudger to remove the two cables that are connected to the wireless adapter.
  8. Lenovo ThinkPad T440p Wireless Adapter Replacement: paso 8, imagen 1 de 2 Lenovo ThinkPad T440p Wireless Adapter Replacement: paso 8, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove one 3 mm screw holding down the wireless adapter. Once it is done, the wireless adapter will move to an upward angle.
  9. Lenovo ThinkPad T440p Wireless Adapter Replacement: paso 9, imagen 1 de 2 Lenovo ThinkPad T440p Wireless Adapter Replacement: paso 9, imagen 2 de 2
    • Remove the wireless adapter.
Conclusión
Christian Abad
Miembro Desde 03/20/19
1,410 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 39
Todo El Tiempo: 1,891
