Saltar al contenido principal
Lenovo ThinkPad T440p Keyboard Replacement
Qué necesitas
  1. Lenovo ThinkPad T440p Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Keyboard Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad T440p Keyboard Replacement: paso 2, imagen 2 de 2
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Keyboard Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T440p Keyboard Replacement: paso 3, imagen 2 de 2
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Using the spudger, move the plastic protector by pressing it down and forward in order to uncover the screws.
  5. Lenovo ThinkPad T440p Keyboard Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad T440p Keyboard Replacement: paso 5, imagen 2 de 2
    • Don't remove the screws; just loosen them.
    • Unscrew the six screws that are attached to the keyboard by using a Phillips #00 screwdriver.
  6. Lenovo ThinkPad T440p Keyboard Replacement: paso 6, imagen 1 de 3 Lenovo ThinkPad T440p Keyboard Replacement: paso 6, imagen 2 de 3 Lenovo ThinkPad T440p Keyboard Replacement: paso 6, imagen 3 de 3
    • Use the spudger to lift the keyboard.
  7. Lenovo ThinkPad T440p Keyboard Replacement: paso 7, imagen 1 de 2 Lenovo ThinkPad T440p Keyboard Replacement: paso 7, imagen 2 de 2
    • Turn the keyboard over.
  8. Lenovo ThinkPad T440p Keyboard Replacement: paso 8, imagen 1 de 3 Lenovo ThinkPad T440p Keyboard Replacement: paso 8, imagen 2 de 3 Lenovo ThinkPad T440p Keyboard Replacement: paso 8, imagen 3 de 3
    • Use the spudger to detach the plastic protection.
  9. Lenovo ThinkPad T440p Keyboard Replacement: paso 9, imagen 1 de 3 Lenovo ThinkPad T440p Keyboard Replacement: paso 9, imagen 2 de 3 Lenovo ThinkPad T440p Keyboard Replacement: paso 9, imagen 3 de 3
    • Use the spudger to disconnect the cables.
  10. Lenovo ThinkPad T440p Keyboard Replacement: paso 10, imagen 1 de 1
    • Remove the keyboard.
Conclusión
7 personas más completaron esta guía.
Christian Abad
Miembro Desde 03/20/19
1,410 Reputación
7 Guías creadas
Equipo
Un comentario
Thanks for the guide. I hate this part lol.
is it true if I slip and knock keys off, they can’t be lit in? I’m told this and it seems true :(
Josh Tree - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 79
Todo El Tiempo: 7,168
