Saltar al contenido principal
Lenovo ThinkPad T440p Fan Replacement
Qué necesitas
  1. Lenovo ThinkPad T440p Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Fan Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad T440p Fan Replacement: paso 2, imagen 2 de 2
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Fan Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T440p Fan Replacement: paso 3, imagen 2 de 2
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Fan Replacement, Back Cover: paso 4, imagen 1 de 2 Lenovo ThinkPad T440p Fan Replacement, Back Cover: paso 4, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
  5. Lenovo ThinkPad T440p Fan Replacement: paso 5, imagen 1 de 1
    • Slide down the back cover.
  6. Lenovo ThinkPad T440p Fan Replacement: paso 6, imagen 1 de 1
    • Remove the back cover.
  7. Lenovo ThinkPad T440p Fan Replacement, Fan: paso 7, imagen 1 de 2 Lenovo ThinkPad T440p Fan Replacement, Fan: paso 7, imagen 2 de 2
    • Using the spudger detach the cable that is connected to the computer.
  8. Lenovo ThinkPad T440p Fan Replacement: paso 8, imagen 1 de 2 Lenovo ThinkPad T440p Fan Replacement: paso 8, imagen 2 de 2
    • Remove the tape that is over the cable.
  9. Lenovo ThinkPad T440p Fan Replacement: paso 9, imagen 1 de 3 Lenovo ThinkPad T440p Fan Replacement: paso 9, imagen 2 de 3 Lenovo ThinkPad T440p Fan Replacement: paso 9, imagen 3 de 3
    • Screws are attached to the heat sink. Do not try to remove them; just have the screws loosened.
    • Unscrew the four screws that are attached to the heat sink by using a Phillips #0 screwdriver.
  10. Lenovo ThinkPad T440p Fan Replacement: paso 10, imagen 1 de 3 Lenovo ThinkPad T440p Fan Replacement: paso 10, imagen 2 de 3 Lenovo ThinkPad T440p Fan Replacement: paso 10, imagen 3 de 3
    • Remove the fan.
Conclusión
Una persona más ha completado esta guía.
Christian Abad
Miembro Desde 03/20/19
1,410 Reputación
7 Guías creadas
Equipo
Un comentario
The guide could go one step further as this model features a replaceable CPU.
cubytus - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 71
Todo El Tiempo: 3,691
