Saltar al contenido principal
Lenovo ThinkPad T431S Screen Replacement
Qué necesitas
  1. Lenovo ThinkPad T431S Screen Replacement, Screen: paso 1, imagen 1 de 2 Lenovo ThinkPad T431S Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use the Jimmy tool to remove the screen bezel with a gentle prying motion.
  2. Lenovo ThinkPad T431S Screen Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad T431S Screen Replacement: paso 2, imagen 2 de 2
    • Remove the four 3.0 mm screws in the four corners of the screen with a Phillips #1 screwdriver bit.
    • While removing the screws, pry the screen off with an opening tool.
    • If your screen is cracked, use caution, as there will be broken glass or sharp parts.
  3. Lenovo ThinkPad T431S Screen Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad T431S Screen Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad T431S Screen Replacement: paso 3, imagen 3 de 3
    • Lift screen off of top panel to reveal LCD power plug/connector.
    • There will be a wire attaching the screen to the rest of the device.
    • Remove the tape on the wire so you can unplug the connection, pulling upwards.
    • Information about disposal of your damaged screen can be found at E-Waste Recycling
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 931
