Saltar al contenido principal
Lenovo ThinkPad T431S Hard Drive Replacement
Qué necesitas
  1. Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: paso 1, imagen 3 de 3
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver to remove the eight 5.0 mm screws from the panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Hard Drive Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad T431S Hard Drive Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad T431S Hard Drive Replacement: paso 2, imagen 3 de 3
    • Remove the single 3 mm screw holding hard drive bracket in place.
    • Grasp the hard drive and remove it from its bracket.
    • Use a slight wiggle motion to carefully disconnect it from the front prong.
Conclusión
2 personas más completaron esta guía.
Un comentario
Can I add SSD without removing HDD? in Lenovo T431s?
Usama Khan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 730
