Saltar al contenido principal
Lenovo ThinkPad T431S Fan Replacement
Qué necesitas
  1. Lenovo ThinkPad T431S Fan Replacement, Fan: paso 1, imagen 1 de 2 Lenovo ThinkPad T431S Fan Replacement, Fan: paso 1, imagen 2 de 2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • Carefully pry off the back panel using the opening tool.
  2. Lenovo ThinkPad T431S Fan Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad T431S Fan Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver bit and remove the four 3.0 mm screws from the heatsink.
  3. Lenovo ThinkPad T431S Fan Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad T431S Fan Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad T431S Fan Replacement: paso 3, imagen 3 de 3
    • Disconnect the cable attached to the fan, pulling the connector straight down.
    • Lift and remove the fan.
Conclusión
2 personas más completaron esta guía.
Un comentario
Well done. I will have a go at fixing the fan on my T430s now that I’ve seen how easy it is to do.
Jocko - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 335
