Saltar al contenido principal
Lenovo ThinkPad T431S Charging Port Replacement
Qué necesitas
  1. Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: paso 1, imagen 1 de 2 Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: paso 1, imagen 2 de 2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Charging Port Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad T431S Charging Port Replacement: paso 2, imagen 2 de 2
    • Unscrew the single, 3.0 mm screw with a Phillips #1 screwdriver bit that holds the charging port housing into place.
  3. Lenovo ThinkPad T431S Charging Port Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T431S Charging Port Replacement: paso 3, imagen 2 de 2
    • Remove the small, white connector cable by prying it from the connector with a plastic opening tool.
    • Remove the charging port assembly.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 38
Todo El Tiempo: 4,006
