Saltar al contenido principal
Lenovo ThinkPad T431S Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad T431S Battery Replacement, Battery: paso 1, imagen 1 de 2 Lenovo ThinkPad T431S Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remember, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off before starting any disassembly.
    • Use a Phillips #1 screwdriver bit to remove the eight 5mm screws from the back panel.
    • Once the screws are loose, use the three opening tools to loosen and remove the back panel.
  2. Lenovo ThinkPad T431S Battery Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad T431S Battery Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad T431S Battery Replacement: paso 2, imagen 3 de 3
    • Carefully unplug the battery cable from the connector on the motherboard, using your fingers to pull the cable straight out of the port.
  3. Lenovo ThinkPad T431S Battery Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad T431S Battery Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad T431S Battery Replacement: paso 3, imagen 3 de 3
    • Unscrew the five 4mm screws that are holding the battery secure with a Phillips #1 screwdriver.
    • Remove the Li-polymer battery by lifting it directly out of the device.
    • Information about disposal of your damaged battery can be found at E-Waste Recycling
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 1,235
