Saltar al contenido principal
Lenovo ThinkPad T430s RAM Stick Replacement
Qué necesitas
  1. Lenovo ThinkPad T430s RAM Stick Replacement, Battery: paso 1, imagen 1 de 3 Lenovo ThinkPad T430s RAM Stick Replacement, Battery: paso 1, imagen 2 de 3 Lenovo ThinkPad T430s RAM Stick Replacement, Battery: paso 1, imagen 3 de 3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: paso 2, imagen 1 de 3 Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: paso 2, imagen 2 de 3 Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: paso 2, imagen 3 de 3
    • With the Phillips #0 screwdriver, loosen the two 30 mm screws holding down the RAM stick plate.
    • Pry up the plate and set it aside.
  3. Lenovo ThinkPad T430s RAM Stick Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad T430s RAM Stick Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad T430s RAM Stick Replacement: paso 3, imagen 3 de 3
    • Use the pointy end of the spudger to bend the bars holding the RAM stick in place.
    • Lift the RAM stick up and out of the stick holder.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 68
Todo El Tiempo: 837
