Saltar al contenido principal
Lenovo ThinkPad T420s RAM Replacement
Qué necesitas
  1. Lenovo ThinkPad T420s RAM Replacement, RAM: paso 1, imagen 1 de 2 Lenovo ThinkPad T420s RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Flip over the laptop so the bottom is facing up.
    • Unscrew the two black 5mm screws on the memory panel with your Phillips #0 screwdriver.
    • These screws are attached to the panel and are not made to be removed.
  2. Lenovo ThinkPad T420s RAM Replacement: paso 2, imagen 1 de 1
    • Push the metal clips away from the RAM.
    • Slide out and lift the RAM.
    • When replacing ram be sure to align correctly and remove carefully to avoid damage.
Conclusión
6 personas más completaron esta guía.
Equipo
Cal Poly, Team 6-13, Maness Spring 2015 Miembro de Cal Poly, Team 6-13, Maness Spring 2015
CPSU-MANESS-S15S6G13
4 Miembros
5 Guías creadas
4 comentarios
This is only part of the game. There is another slot located under the keyboard. Lenovo wants this slot to be used first when only one of the two are needed.
cosy69 - Contestar
It may require a BIOS update (or not) but the Lenovo T420s supports 16GB of RAM.
Bryan Montford - Contestar
This is not the Lenovo Thinkpad T420. You can Tell by the RAM memory Slot Cover and the Position the RAM is put into its slot. the T420 RAM is Vertical Compared with being Horizontal in this Picture. that includes the cover also. Then the Battery Slot is a Dead Giveaway clue. The T420 Battery slot is in the middle. and this Picture has the battery slot to bthe left. Sorry Not Even Close. None of the screws he removes are on the T420. so this is Completely Useless. Thanks
Keith Cloward - Contestar
@Keith Cloward
This is a guide for the T420S, not the T420.
Eric Van de Kerckhove - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 37
Todo El Tiempo: 9,551
