Introducción
If your laptop is not charging correctly you can replace the power jack using this guide.
Herramientas
Partes
No se especificaron partes.
Flip your laptop over so the bottom is facing up.
Remove the memory panel by removing two black 5mm screws using the Phillips #0.
Remove the memory panel.
Remove the additional thirteen 5 mm screws with your Phillips #0 screwdriver.
Remove the two 2.5 X 5 mm screws from the back of your laptop.
Remove the 3 mm screw from the back of the laptop using the same screwdriver.
13 personas más completaron esta guía.
6 comentarios
This is not the Lenovo Thinkpad T420. You can Tell by the RAM memory Slot Cover and the Position the RAM is put into its slot. the T420 RAM is Vertical Compared with being Horizontal in this Picture. that includes the cover also. Then the Battery Slot is a Dead Giveaway clue. The T420 Battery slot is in the middle. and this Picture has the battery slot to bthe left. Sorry Not Even Close. None of the screws he removes are on the T420. so this is Completely Useless. Thanks
This is T420s!
it is not easy to replace a power jack for Lenovo ThinkPad T420S because it requires soldering job and people might burn the board while doing the job, you are replacing a power jack board, just disassemble and assemble the laptop, here is a seller for Lenovo ThinkPad T420S power jack board: http://www.dcincable.com/04w1699-04w3997...
https://www.youtube.com/watch?v=rGMFSdFW... This is how you test adapter, this guy also shows you in another video how to test your jack.
