Saltar al contenido principal
Lenovo ThinkPad T420s Hard Disk Drive Replacement
Qué necesitas
  1. Lenovo ThinkPad T420s Hard Disk Drive Replacement, Hard Disk Drive: paso 1, imagen 1 de 2 Lenovo ThinkPad T420s Hard Disk Drive Replacement, Hard Disk Drive: paso 1, imagen 2 de 2
    • Turn the laptop upside down.
  2. Lenovo ThinkPad T420s Hard Disk Drive Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad T420s Hard Disk Drive Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to unscrew and remove the screw on the hard drive compartment at the bottom right of the device.
  3. Lenovo ThinkPad T420s Hard Disk Drive Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T420s Hard Disk Drive Replacement: paso 3, imagen 2 de 2
    • Pull the hard driver compartment cover up, then out by pulling on the edge near the screw hole.
  4. Lenovo ThinkPad T420s Hard Disk Drive Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad T420s Hard Disk Drive Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad T420s Hard Disk Drive Replacement: paso 4, imagen 3 de 3
    • Pull the hard drive out of the hard drive compartment.
  5. Lenovo ThinkPad T420s Hard Disk Drive Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad T420s Hard Disk Drive Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad T420s Hard Disk Drive Replacement: paso 5, imagen 3 de 3
    • Pull the red rails off both sides of the hard drive.
    • The red rails will be put back on the new hard drive that you install.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 60
Todo El Tiempo: 1,411
