Saltar al contenido principal
Lenovo ThinkPad T400s LCD Screen Replacement
Qué necesitas
  1. Lenovo ThinkPad T400s LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • Use a #0 Phillips head screwdriver to remove the two 3mm screws that hold the screen bezel in place.
  2. Lenovo ThinkPad T400s LCD Screen Replacement: paso 2, imagen 1 de 1
    • Using the plastic opening tool, gently pry off the plastic LCD screen frame around the entire perimeter.
    • Be careful while prying the frame off, because the plastic tabs that hold it in may break.
  3. Lenovo ThinkPad T400s LCD Screen Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T400s LCD Screen Replacement: paso 3, imagen 2 de 2
    • Remove the LCD connector by pulling on the ribbon cable at the connection.
  4. Lenovo ThinkPad T400s LCD Screen Replacement: paso 4, imagen 1 de 1
    • Lift the LCD screen out to replace.
    • Make sure to remove the screen with both hands and from opposite edges of the screen.
Conclusión
7 personas más completaron esta guía.
Equipo
Cal Poly, Team 6-18, Maness Spring 2015 Miembro de Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 21
Todo El Tiempo: 2,565
