Saltar al contenido principal
Lenovo ThinkPad T400s Keyboard Replacement
Qué necesitas
  1. Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: paso 1, imagen 1 de 2 Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Remove the Phillips #0-6mm screw.
    • Lift up the back cover to the RAM cards.
  2. Lenovo ThinkPad T400s Keyboard Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad T400s Keyboard Replacement: paso 2, imagen 2 de 2
    • Pull the lock for the baterry to the left to unlock.
    • While holding the tab in the unlocked position, remove the battery.
  3. Lenovo ThinkPad T400s Keyboard Replacement: paso 3, imagen 1 de 1
    • Remove the three Phillips #0-6mm screws on the back panel.
    • These screws are marked with a keyboard symbol next to them.
  4. Lenovo ThinkPad T400s Keyboard Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad T400s Keyboard Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad T400s Keyboard Replacement: paso 4, imagen 3 de 3
    • Turn the computer over and open the lid.
    • Wedge the small metal spudger between the palm rest and the keyboard.
  5. Lenovo ThinkPad T400s Keyboard Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad T400s Keyboard Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad T400s Keyboard Replacement: paso 5, imagen 3 de 3
    • Lift up the keyboard, but be careful not to completely remove.
    • Don't lift the keyboard too quickly, there is a connector cable you must disconnect first.
    • Wedge the small plastic opening tool underneath copper band and tilt back.
    • Remove keyboard to replace.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 6-18, Maness Spring 2015 Miembro de Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 1,478
