Saltar al contenido principal
Lenovo ThinkPad T400 Motherboard Replacement
Qué necesitas
  1. Lenovo ThinkPad T400 Motherboard Replacement, Removing the battery: paso 1, imagen 1 de 1
    • Start with the bottom of the laptop facing you. Pull the small tab that is marked by the padlock icons in the direction shown by the red arrow.
    • At the same time, pull the battery out in the direction shown by the yellow arrows.
  2. Lenovo ThinkPad T400 Motherboard Replacement, Removing the 2.5" and Ultrabay drives: paso 2, imagen 1 de 2 Lenovo ThinkPad T400 Motherboard Replacement, Removing the 2.5" and Ultrabay drives: paso 2, imagen 2 de 2
    • Unscrew the 2 small Phillips screws that hold the 2.5" bay cover and the Ultrabay slider in place.
    • The 2.5" bay cover should now come loose, so pull it out. Under the ultrabay drive, you will find a small slider. Slide it in the direction shown in yellow and a tab should pop out.
    • Pull both the 2.5" and the Ultrabay drives by their respective tabs, shown in green.
    • The Ultrabay tab can easily snap off if left pulled out, so push it back in after you remove the drive.
  3. Lenovo ThinkPad T400 Motherboard Replacement, Removing the palmrest and keyboard: paso 3, imagen 1 de 1
    • In order to remove the palmrest and the keyboard, you need to undo 5 long Phillips screws. They are marked on the case with small embossed keyboard symbols, and are circled in red here.
Conclusión
Una persona más ha completado esta guía.
Sample Text
Miembro Desde 02/14/17
276 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 22
Todo El Tiempo: 509
