Introducción
Follow this guide to remove and replace the LPCAMM2 memory module (aka RAM) on your Lenovo ThinkPad T14 Gen 7 laptop.
Qué necesitas
For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
Use your fingers to grab and lift the top-right corner of the base cover near the hinge.
Repeat at the top-left corner.
Use your fingers to squeeze the two latches on either side of the battery connector.
While squeezing the latches, lift the top edge of the battery up.
Use a Phillips screwdriver to loosen the three captive screws securing the LPCAMM2 cover.
Grab the edges of the LPCAMM2 memory module and lift straight up to remove it.
2 personas más completaron esta guía.
