Introducción
In this guide, we will be replacing the screen on the Lenovo ThinkPad T14 Gen 3. This guide is suitable if you have a broken LCD, a cracked screen, or other issues.
Before you begin this guide, power off and unplug your laptop.
Qué necesitas
Use a JIS #1 screwdriver to loosen the seven screws from the back panel.
Turn each screw counter-clockwise at least 3 turns and move on to the next step.
Place the end of a spudger or opening tool into the seam to gently separate the back cover from the rest of the device.
Slide the opening tool around the perimeter of the device to release the clips that hold the back panel to the device.
Remove the back panel.
Use a JIS #1 screwdriver to remove six M2 x 5 mm screws that hold the battery in place.
Use the spudger to gently pry the edges of the bezel, carefully removing it. Then, gently remove it and set it aside.
Flip the screen over to reveal the display connector.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Una persona más ha completado esta guía.
