Saltar al contenido principal
Lenovo ThinkPad L490 Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad L490 Battery Replacement, Lower Case: paso 1, imagen 1 de 2 Lenovo ThinkPad L490 Battery Replacement, Lower Case: paso 1, imagen 2 de 2
    • Completely shut down your device and disconnect any peripheries before beginning.
    • Lay the laptop down with the lower case facing up.
    • Use a Phillips #00 screwdriver to remove eight 3 mm screws that secure the lower case.
  2. Lenovo ThinkPad L490 Battery Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad L490 Battery Replacement: paso 2, imagen 2 de 2
    • Lift the lower case up and off of the chassis.
    • If necessary, insert an opening pick into the gap between the lower case and chassis and pry around the entire perimeter until the lower case fully releases.
  3. Lenovo ThinkPad L490 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Grip the battery connector and pull it directly out of its motherboard socket.
  4. Lenovo ThinkPad L490 Battery Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad L490 Battery Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad L490 Battery Replacement: paso 4, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the three m2 x 2.5 mm screws that secure the battery.
    • Lift the battery up and out of the chassis.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
Sky
Miembro Desde 09/05/24
85 Reputación
1 Guía escrita
Equipo
Gateway, Team 8-4, Gonzalez Fall 2024 Miembro de Gateway, Team 8-4, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G4
Miembros de 4
4 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 23
Ultimos 30 días: 80
Todo El Tiempo: 221
