Saltar al contenido principal
Lenovo ThinkPad Helix Screen Replacement
Qué necesitas
  1. Lenovo ThinkPad Helix Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo ThinkPad Helix Screen Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad Helix Screen Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad Helix Screen Replacement: paso 2, imagen 3 de 3
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo ThinkPad Helix Screen Replacement: paso 3, imagen 1 de 1
    • Once the cables are disconnected, remove the screen.
Conclusión
3 personas más completaron esta guía.
Equipo
Gateway, Team S1-G6, Saknee Fall 2019 Miembro de Gateway, Team S1-G6, Saknee Fall 2019
GCC-SAKNEE-F19S1G6
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 29
Todo El Tiempo: 1,679
