Saltar al contenido principal
Lenovo ThinkPad Helix Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad Helix Battery Replacement, Screen: paso 1, imagen 1 de 1
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo ThinkPad Helix Battery Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad Helix Battery Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad Helix Battery Replacement: paso 2, imagen 3 de 3
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo ThinkPad Helix Battery Replacement: paso 3, imagen 1 de 1
    • Once the cables are disconnected, remove the screen.
  4. Lenovo ThinkPad Helix Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Using a Phillips #00 screwdriver, unscrew the four nylon-coated 3 mm screws holding the battery in place.
  5. Lenovo ThinkPad Helix Battery Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad Helix Battery Replacement: paso 5, imagen 2 de 2
    • Disconnect the battery cable from the motherboard.
    • Lift the battery out of the device.
Conclusión
7 personas más completaron esta guía.
Equipo
Gateway, Team S1-G6, Saknee Fall 2019 Miembro de Gateway, Team S1-G6, Saknee Fall 2019
GCC-SAKNEE-F19S1G6
4 Miembros
3 Guías creadas
Un comentario
Hi, would you possibly have an explanation as to why a replacement battery is still not charging and yielding error messages? Thank you.
M.H. L. - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 23
Ultimos 30 días: 84
Todo El Tiempo: 6,872
