Saltar al contenido principal
Lenovo ThinkPad HK11e Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad HK11e Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the Lenovo laptop is shut off.
    • Turn over laptop and lay it on its face exposing the back-plate screws.
  2. Lenovo ThinkPad HK11e Battery Replacement: paso 2, imagen 1 de 1
    • Find the six screws that hold together the back plate.
    • Carefully unscrew the six 3.3 mm screws that fasten the back plate using the T5 Torx screwdriver.
  3. Lenovo ThinkPad HK11e Battery Replacement: paso 3, imagen 1 de 1
    • Use a plastic opening tool or a spudger to carefully remove the back plate.
  4. Lenovo ThinkPad HK11e Battery Replacement: paso 4, imagen 1 de 1
    • Battery is located in the bottom right portion of the laptop.
    • Find the three screws that mount the battery.
    • Carefully unscrew the three 3.5 mm screws that fasten the battery down using the T5 Torx screwdriver.
  5. Lenovo ThinkPad HK11e Battery Replacement: paso 5, imagen 1 de 1
    • Notice a connector that joins the battery to the laptop.
    • Slowly disconnect the connector by pulling back on the six-wire harness.
  6. Lenovo ThinkPad HK11e Battery Replacement: paso 6, imagen 1 de 1
    • Remove the battery from its assigned location.
  7. Lenovo ThinkPad HK11e Battery Replacement: paso 7, imagen 1 de 1
    • Reverse steps to mount new battery correctly.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 44
Todo El Tiempo: 251
