Introducción
If you need to replace the battery, use this guide to access and remove the battery from this device. For this guide you will need a plastic opening tool, a Phillips #0 and Phillips #00 screwdriver.
Qué necesitas
Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
Una persona más ha completado esta guía.
