Saltar al contenido principal
Lenovo ThinkCentre M92p Hard Drive Replacement
Qué necesitas
  1. Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: paso 1, imagen 3 de 3
    • Power off your ThinkCentre M92p, and unplug the power cable from the electrical outlet.
  2. Lenovo ThinkCentre M92p Hard Drive Replacement: paso 2, imagen 1 de 2 Lenovo ThinkCentre M92p Hard Drive Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the middle black screw located on the back of the ThinkCentre.
  3. Lenovo ThinkCentre M92p Hard Drive Replacement: paso 3, imagen 1 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: paso 3, imagen 2 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: paso 3, imagen 3 de 3
    • Use your thumbs and slide the metal housing towards the front, to remove the cover.
  4. Lenovo ThinkCentre M92p Hard Drive Replacement: paso 4, imagen 1 de 2 Lenovo ThinkCentre M92p Hard Drive Replacement: paso 4, imagen 2 de 2
    • Unplug the black connector from the damaged hard drive.
  5. Lenovo ThinkCentre M92p Hard Drive Replacement: paso 5, imagen 1 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: paso 5, imagen 2 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: paso 5, imagen 3 de 3
    • Use the Phillips #1 screwdriver to remove the two black screws holding the hard drive to the chassis.
  6. Lenovo ThinkCentre M92p Hard Drive Replacement: paso 6, imagen 1 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: paso 6, imagen 2 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: paso 6, imagen 3 de 3
    • Do not try to remove the hard drive right away .There is a red/black cable connected to the motherboard, right below the hard drive. Gently disconnect it from the *green* motherboard***.
  7. Lenovo ThinkCentre M92p Hard Drive Replacement: paso 7, imagen 1 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: paso 7, imagen 2 de 3 Lenovo ThinkCentre M92p Hard Drive Replacement: paso 7, imagen 3 de 3
    • Flip over the disconnected caddy/tray and use the Phillips #1 screwdriver to remove the four screws from the bottom. Then remove the hard drive.
Conclusión
3 personas más completaron esta guía.
Innocent bakajika
Miembro Desde 09/01/21
217 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 31
Ultimos 30 días: 132
Todo El Tiempo: 5,260
