Introducción
If your battery seems to drain quickly while in standby mode, just follow the simple steps in this guide and you will be back in business in no time!
Qué necesitas
Gently insert a spudger into one of the bottom corners between the screen and body case.
Slide the spudger along the inside of the crack in order to pry the case open.
15 personas más completaron esta guía.
