Saltar al contenido principal
  1. Start at the microSD slot. Use the opening pick to slide underneath the back cover of the tablet. Slide the opening pick around the tablet until the back cover is off.
    • Start at the microSD slot.
    • Use the opening pick to slide underneath the back cover of the tablet.
    • Slide the opening pick around the tablet until the back cover is off.
  2. Remove the 8 screws with a Phillips #000 screwdriver [bit]. There is a screw under the blue "s" sticker. Remove tape holding plate down.
    • Remove the 8 screws with a Phillips #000 screwdriver [bit].
    • There is a screw under the blue "s" sticker.
    • Remove tape holding plate down.
    • Use precision tweezers or your fingers to remove plate.
  3. Remove yellow tape. Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
    • Remove yellow tape.
    • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
  4. Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery. Once the tabs are off, lift the battery up from the frame. Do not bend or puncture the battery.
    • Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
    • Once the tabs are off, lift the battery up from the frame.
    • Do not bend or puncture the battery.
  5. Use a spudger to lift the rear camera press-fit connector up and free. Use tweezers to lift the rear camera out of the frame.
    • Use a spudger to lift the rear camera press-fit connector up and free.
    • Use tweezers to lift the rear camera out of the frame.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 284
