Saltar al contenido principal
Lenovo Tab 4 8 MicroSD Card Reader Replacement
Qué necesitas
  1. Lenovo Tab 4 8 MicroSD Card Reader Replacement, Battery: paso 1, imagen 1 de 3 Lenovo Tab 4 8 MicroSD Card Reader Replacement, Battery: paso 1, imagen 2 de 3 Lenovo Tab 4 8 MicroSD Card Reader Replacement, Battery: paso 1, imagen 3 de 3
    • Start at the microSD slot.
    • Use the opening pick to slide underneath the back cover of the tablet.
    • Slide the opening pick around the tablet until the back cover is off.
  2. Lenovo Tab 4 8 MicroSD Card Reader Replacement: paso 2, imagen 1 de 3 Lenovo Tab 4 8 MicroSD Card Reader Replacement: paso 2, imagen 2 de 3 Lenovo Tab 4 8 MicroSD Card Reader Replacement: paso 2, imagen 3 de 3
    • Remove the 8 screws with a Phillips #000 screwdriver [bit].
    • There is a screw under the blue "s" sticker.
    • Remove tape holding plate down.
    • Use precision tweezers or your fingers to remove plate.
  3. Lenovo Tab 4 8 MicroSD Card Reader Replacement: paso 3, imagen 1 de 2 Lenovo Tab 4 8 MicroSD Card Reader Replacement: paso 3, imagen 2 de 2
    • Remove yellow tape.
    • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
  4. Lenovo Tab 4 8 MicroSD Card Reader Replacement: paso 4, imagen 1 de 3 Lenovo Tab 4 8 MicroSD Card Reader Replacement: paso 4, imagen 2 de 3 Lenovo Tab 4 8 MicroSD Card Reader Replacement: paso 4, imagen 3 de 3
    • Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
    • Once the tabs are off, lift the battery up from the frame.
    • Do not bend or puncture the battery.
  5. Lenovo Tab 4 8 MicroSD Card Reader Replacement, MicroSD Card Reader: paso 5, imagen 1 de 2 Lenovo Tab 4 8 MicroSD Card Reader Replacement, MicroSD Card Reader: paso 5, imagen 2 de 2
    • There is a yellow tape holding the microSD card reader connector. Use tweezers to hold down the tape.
    • Gently lift the tab on the microSD card reader's ZIF connector, and gently pull the ribbon cable free.
  6. Lenovo Tab 4 8 MicroSD Card Reader Replacement: paso 6, imagen 1 de 2 Lenovo Tab 4 8 MicroSD Card Reader Replacement: paso 6, imagen 2 de 2
    • Lift the microSD card reader with tweezers or your fingers.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 795
