Saltar al contenido principal
Lenovo Tab 2 A8 Speaker Replacement
Qué necesitas
  1. Lenovo Tab 2 A8 Speaker Replacement, Removing the Back Panel: paso 1, imagen 1 de 3 Lenovo Tab 2 A8 Speaker Replacement, Removing the Back Panel: paso 1, imagen 2 de 3 Lenovo Tab 2 A8 Speaker Replacement, Removing the Back Panel: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Speaker Replacement: paso 2, imagen 1 de 3 Lenovo Tab 2 A8 Speaker Replacement: paso 2, imagen 2 de 3 Lenovo Tab 2 A8 Speaker Replacement: paso 2, imagen 3 de 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Speaker Replacement, Speaker: paso 3, imagen 1 de 3 Lenovo Tab 2 A8 Speaker Replacement, Speaker: paso 3, imagen 2 de 3 Lenovo Tab 2 A8 Speaker Replacement, Speaker: paso 3, imagen 3 de 3
    • Using a counterclockwise motion with the Phillips #000 screwdriver, unscrew the three M1.4 × 2.5 screws that hold the white plastic speaker housing in place.
    • Pry off the speaker housing utilizing a metal spudger.
  4. Lenovo Tab 2 A8 Speaker Replacement: paso 4, imagen 1 de 1
    • Insert a plastic probe through the tab and pry to remove the speaker from its socket.
    • Be careful not to damage the wires attached to the speaker. Don't forcibly remove the speaker from its socket. The speaker is magnetic, don't use metal tools.
  5. Lenovo Tab 2 A8 Speaker Replacement: paso 5, imagen 1 de 1
    • Using a soldering iron, desolder the contacts that connect the speaker wires to the speaker chip.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 729
