Introducción
This guide shows you how to gain access to the buzzer ringer component of the speaker for its replacement.
Qué necesitas
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
Using a counterclockwise motion with the Phillips #000 screwdriver, unscrew the three M1.4 × 2.5 screws that hold the white plastic speaker housing in place.
Pry off the speaker housing utilizing a metal spudger.
