Saltar al contenido principal
Lenovo Tab 2 A8 Battery Replacement
Qué necesitas
  1. Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: paso 1, imagen 1 de 3 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: paso 1, imagen 2 de 3 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Battery Replacement: paso 2, imagen 1 de 3 Lenovo Tab 2 A8 Battery Replacement: paso 2, imagen 2 de 3 Lenovo Tab 2 A8 Battery Replacement: paso 2, imagen 3 de 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Battery Replacement, Battery: paso 3, imagen 1 de 2 Lenovo Tab 2 A8 Battery Replacement, Battery: paso 3, imagen 2 de 2
    Comprar
    • Using a counterclockwise motion with the Phillips #000 screwdriver, remove the M1.4 × 2.5 screw that holds down the copper strip connected to the battery.
    • With a pair of Tweezers, carefully unplug the strip connecting the battery to the motherboard.
  4. Lenovo Tab 2 A8 Battery Replacement: paso 4, imagen 1 de 3 Lenovo Tab 2 A8 Battery Replacement: paso 4, imagen 2 de 3 Lenovo Tab 2 A8 Battery Replacement: paso 4, imagen 3 de 3
    • Working your way around the edge of the battery, pry out the battery using a plastic opening tool
    • Be aware that the battery is held in by double-sided tape on the underside
Conclusión
5 personas más completaron esta guía.
2 comentarios
Thanks... but where do we find a replacement battery?
sebtrudel - Contestar
I fixit might have a replacement battery
storm builder - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 69
Todo El Tiempo: 11,665
