Saltar al contenido principal
Lenovo Tab 2 A7-20F Battery Replacement
Qué necesitas
  1. Lenovo Tab 2 A7-20F Battery Replacement, Case: paso 1, imagen 1 de 2 Lenovo Tab 2 A7-20F Battery Replacement, Case: paso 1, imagen 2 de 2
    • Starting at any point along the seam of the case carefully pry it open with the metal spudger, slowly working your way around the outside until the case can come apart.
  2. Lenovo Tab 2 A7-20F Battery Replacement, Battery: paso 2, imagen 1 de 2 Lenovo Tab 2 A7-20F Battery Replacement, Battery: paso 2, imagen 2 de 2
    • The battery is connected to the motherboard by the thin wire shown here.
    • Pull up gently on the yellow tape to access the connector.
  3. Lenovo Tab 2 A7-20F Battery Replacement: paso 3, imagen 1 de 1
    • Gently detach the connector from the motherboard by pulling up on it.
  4. Lenovo Tab 2 A7-20F Battery Replacement: paso 4, imagen 1 de 3 Lenovo Tab 2 A7-20F Battery Replacement: paso 4, imagen 2 de 3 Lenovo Tab 2 A7-20F Battery Replacement: paso 4, imagen 3 de 3
    • There is double-sided tape inside the case.
    • Use the spudger tool to loosen the bond of the adhesive from the double sided tape.
    • Separate the battery from the case.
Conclusión
2 personas más completaron esta guía.
Thanh
Miembro Desde 09/21/17
357 Reputación
3 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 3,190
