Saltar al contenido principal
Lenovo Tab 2 A10-70 Rear Facing Camera Replacement
Qué necesitas
  1. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement, Rear Facing Camera: paso 1, imagen 1 de 1
    • Before removing the camera, make sure the device is powered off
    • Use a plastic opening tool to pry open the back cover of the tablet..
  2. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: paso 2, imagen 1 de 1
    • Locate the cable that is connecting the camera to the tablet
  3. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: paso 3, imagen 1 de 1
    • Disconnect the cable that is connecting the camera to the tablet
  4. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: paso 4, imagen 1 de 2 Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: paso 4, imagen 2 de 2
    • Simply remove the camera from the tablet by lifting it up
    • Repeat Steps in reverse order with a new camera for reassembly
Conclusión
Equipo
USF Tampa, Team 12-6, Eyestone Spring 2016 Miembro de USF Tampa, Team 12-6, Eyestone Spring 2016
USFT-EYESTONE-S16S12G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 906
