Introducción
The screen on the Lenovo Tab 2 A10-70 is a pain in the tush to remove but if you can get past the adhesive it's not to hard!!!! Don't Give up. (Please excuse the pictures in this guide, the preggo body looks even bigger in them!!!!)
It is extremely easy to remove the plastic casing. Just slide your spudger (or fingernail if they are strong) around the edge to remove
Using your fingernail or tweezers lift the holding flap and disconnect the digitizer cable for the old screen
Please be very careful!, This glass shatters easily and shards will go flying if you are rough
The glass is connected to the frame and LCD by the world's strongest adhesive, .... took me well over an hour to remove the old screen
Using a heat gun (high powered blow dryer) or those of you lucky enough to have an iopener kit slowly heat your way around the glass, start in a corner and work your spudger in.
Make sure you slide your spudger straight in to avoid the lcd There is a nice gap but the adhesive is two part!
Clean your Edges
Using your spudger or a razor knife clean off any left behind adhesive
Carefully Slide the digitizer cable through the opening in the case
Flip over case and reconnect the new digitizer cable
I then tested to make sure the screen and digitizer worked before adhesive :)
The Screen I ordered came with adhesive already on it, but I added some 3M tape too
Press the Screen firmly into place
Then replace the back cover!
18 personas más completaron esta guía.
9 comentarios
Hi Amber,
Thank you for the guide.
How's the replacement screen quality? Can I know where you bought the screen from? I need to replace my screen. Thinking of buying it from the same supplier. Would want a screen with adhesive too.
Thanks
Richard.
I don't quite know but it looks like a regular bootleg one
I just completed this, using a proper heat Gun it took about 10 minutes.
Ebay screen, oem tagged, apparently no adhesive on it.
I love the guide and you have encouraged me to try to replace my screen. Where did you order the replacement screen and did you order just the new glass?
Thanks,
Jack
did you replace the glass/digitiser only, or did you also replace the lcd ? the title suggests glass/digitiser but step 6 refers to a "new screen" sorry for the confusion
