Saltar al contenido principal
Lenovo S20-30 Keyboard Replacement
Qué necesitas
  1. Lenovo S20-30 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
  2. Lenovo S20-30 Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide the manual battery latch to the unlock position, so that the red is showing.
  3. Lenovo S20-30 Keyboard Replacement: paso 3, imagen 1 de 2 Lenovo S20-30 Keyboard Replacement: paso 3, imagen 2 de 2
    • Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
    • Grab new Lenovo S20-30 battery for replacement.
  4. Lenovo S20-30 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 Lenovo S20-30 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 Lenovo S20-30 Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Remove the two front rubber feet using a long metal spudger.
    • Use your Phillips #0 screwdriver to remove the two M2.5 x 5mm flat-head screws located underneath the pads.
  5. Lenovo S20-30 Keyboard Replacement: paso 5, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the nine M2 x 4mm flat head screws located on the outer edges on the back of the laptop.
    • Make sure to keep these screws separated from future screws that will be disassembled throughout this process.
  6. Lenovo S20-30 Keyboard Replacement: paso 6, imagen 1 de 2 Lenovo S20-30 Keyboard Replacement: paso 6, imagen 2 de 2
    • Use the long metal spudger to pry open the bottom half of the laptop.
    • Gently lift the cover off to reveal the motherboard.
  7. Lenovo S20-30 Keyboard Replacement: paso 7, imagen 1 de 2 Lenovo S20-30 Keyboard Replacement: paso 7, imagen 2 de 2
    • Remove the four M2 x 3mm flat-head screw using a Phillips #000 screwdriver.
  8. Lenovo S20-30 Keyboard Replacement: paso 8, imagen 1 de 2 Lenovo S20-30 Keyboard Replacement: paso 8, imagen 2 de 2
    • Flip over laptop and open the lid to have access to the keyboard.
    • Use a plastic opening tool to pry apart the keyboard.
  9. Lenovo S20-30 Keyboard Replacement: paso 9, imagen 1 de 3 Lenovo S20-30 Keyboard Replacement: paso 9, imagen 2 de 3 Lenovo S20-30 Keyboard Replacement: paso 9, imagen 3 de 3
    • A connector is attached to the keyboard.
    • Remove it by gently pulling it outward.
  10. Lenovo S20-30 Keyboard Replacement: paso 10, imagen 1 de 1
    • Grab replacement keyboard to insert back into place.
Conclusión
3 personas más completaron esta guía.
Un comentario
where can i find a replacement keyboard/ or what model # do i need?
ed paz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 21
Todo El Tiempo: 1,259
