Saltar al contenido principal
Lenovo S20-30 Display Monitor Replacement
Qué necesitas
Resumen del Video
  1. Lenovo S20-30 Display Monitor Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
  2. Lenovo S20-30 Display Monitor Replacement: paso 2, imagen 1 de 1
    • Slide the manual battery latch to the unlock position, so that the red is showing.
  3. Lenovo S20-30 Display Monitor Replacement: paso 3, imagen 1 de 2 Lenovo S20-30 Display Monitor Replacement: paso 3, imagen 2 de 2
    • Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
    • Grab new Lenovo S20-30 battery for replacement.
  4. Lenovo S20-30 Display Monitor Replacement, Display Monitor: paso 4, imagen 1 de 2 Lenovo S20-30 Display Monitor Replacement, Display Monitor: paso 4, imagen 2 de 2
    • Pry open the frame using a plastic opening tool.
    • Pull frame upward to remove it.
  5. Lenovo S20-30 Display Monitor Replacement: paso 5, imagen 1 de 2 Lenovo S20-30 Display Monitor Replacement: paso 5, imagen 2 de 2
    • Unscrew four M2 x 3mm screws using a Phillips #000 screwdriver.
  6. Lenovo S20-30 Display Monitor Replacement: paso 6, imagen 1 de 2 Lenovo S20-30 Display Monitor Replacement: paso 6, imagen 2 de 2
    • Slowly remove display monitor to reveal the connector.
    • Remove the connector by gently pulling it out.
  7. Lenovo S20-30 Display Monitor Replacement: paso 7, imagen 1 de 1
    • Replace with new display monitor.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 1,060
