Introducción
This will show you how to remove the keyboard on the Lenovo N23 Yoga Chromebook
  1. Flip the computer over. Remove the 9 screws surrounding the edges of the computer. Remove the single screw near the center of the computer.
    • Flip the computer over.
    • Remove the 9 screws surrounding the edges of the computer.
    • Remove the single screw near the center of the computer.
  2. Use a smaller plastic panel popping tool to begin (if you have one). You may increase to a larger size as you go (if you have one)
    • Use a smaller plastic panel popping tool to begin (if you have one). You may increase to a larger size as you go (if you have one)
    • Slowly work your way around the edges of the computer.
    • Closer to the screen the clips will be sturdier, use a little more force but still be cautious.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. On the main board, lift up on the black tabs of the connectors that are connected to the ribbons.
    • On the main board, lift up on the black tabs of the connectors that are connected to the ribbons.
    • Remove the ribbon connectors gently from the main board.
  5. The keyboard should be free and disconnected from the rest of the computer.
    • The keyboard should be free and disconnected from the rest of the computer.
Conclusión
2 personas más completaron esta guía.
Drew Canada
Miembro Desde 03/04/18
998 Reputación
4 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 10
Últimos 30 Días: 34
Todo El Tiempo: 279
