Introducción
This guide will show you how to remove the wireless card from your chromebook. You can replace the wireless card once you have removed it.
Qué necesitas
Flip the Chromebook so that the bottom is facing up.
Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
Use a spudger to remove each of the 4 rubber feet.
Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
Flip the Chromebook back over and open the screen.
Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
Use a Philips #1 screwdriver to remove the 3.6 mm screw from the back panel.
2 personas más completaron esta guía.
Un comentario
Very well explained and photographed. My first attempt at a laptop repair and this guide made it possible.
Thanks!
