Saltar al contenido principal
Lenovo N22 Chromebook Speakers Replacement
Qué necesitas
  1. Lenovo N22 Chromebook Speakers Replacement, Keyboard: paso 1, imagen 1 de 3 Lenovo N22 Chromebook Speakers Replacement, Keyboard: paso 1, imagen 2 de 3 Lenovo N22 Chromebook Speakers Replacement, Keyboard: paso 1, imagen 3 de 3
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Speakers Replacement: paso 2, imagen 1 de 3 Lenovo N22 Chromebook Speakers Replacement: paso 2, imagen 2 de 3 Lenovo N22 Chromebook Speakers Replacement: paso 2, imagen 3 de 3
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Speakers Replacement: paso 3, imagen 1 de 2 Lenovo N22 Chromebook Speakers Replacement: paso 3, imagen 2 de 2
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Speakers Replacement: paso 4, imagen 1 de 1
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
  5. Lenovo N22 Chromebook Speakers Replacement, Battery: paso 5, imagen 1 de 2 Lenovo N22 Chromebook Speakers Replacement, Battery: paso 5, imagen 2 de 2
    • Separate the battery cable from the motherboard by wedging the edge of a plastic opening tool between the black cable connector and the silver socket on the motherboard.
    • Pull the battery cable straight towards you, away from the silver socket.
  6. Lenovo N22 Chromebook Speakers Replacement: paso 6, imagen 1 de 2 Lenovo N22 Chromebook Speakers Replacement: paso 6, imagen 2 de 2
    • Use a Philips #1 screwdriver to remove the three 4.3 mm screws securing the battery.
  7. Lenovo N22 Chromebook Speakers Replacement: paso 7, imagen 1 de 2 Lenovo N22 Chromebook Speakers Replacement: paso 7, imagen 2 de 2
    • Lift up on the tabs that were held down by the screws to remove the battery.
  8. Lenovo N22 Chromebook Speakers Replacement, Speakers: paso 8, imagen 1 de 1
    • Use the edge of the opening tool to separate the speaker cable connector from the black socket on the motherboard.
    • Pull the cables towards you and away from the socket.
  9. Lenovo N22 Chromebook Speakers Replacement: paso 9, imagen 1 de 2 Lenovo N22 Chromebook Speakers Replacement: paso 9, imagen 2 de 2
    • Use the pointed end of the spudger to pop the speaker up and off of the two posts.
  10. Lenovo N22 Chromebook Speakers Replacement: paso 10, imagen 1 de 2 Lenovo N22 Chromebook Speakers Replacement: paso 10, imagen 2 de 2
    • Slide the wire that connects the two separate speakers out from under the guide tabs.
  11. Lenovo N22 Chromebook Speakers Replacement: paso 11, imagen 1 de 2 Lenovo N22 Chromebook Speakers Replacement: paso 11, imagen 2 de 2
    • Use the flat end of the spudger to pop the speaker up and off of the two posts.
Conclusión
Una persona más ha completado esta guía.
Kevin Yerina
Miembro Desde 04/26/17
453 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S21-G1, Livingston Spring 2017 Miembro de Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 747
