Saltar al contenido principal
Lenovo N22 Chromebook Keyboard Replacement
Qué necesitas
  1. Lenovo N22 Chromebook Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 Lenovo N22 Chromebook Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 Lenovo N22 Chromebook Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Keyboard Replacement: paso 2, imagen 1 de 3 Lenovo N22 Chromebook Keyboard Replacement: paso 2, imagen 2 de 3 Lenovo N22 Chromebook Keyboard Replacement: paso 2, imagen 3 de 3
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Keyboard Replacement: paso 3, imagen 1 de 2 Lenovo N22 Chromebook Keyboard Replacement: paso 3, imagen 2 de 2
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Keyboard Replacement: paso 4, imagen 1 de 1
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
Conclusión
8 personas más completaron esta guía.
Equipo
Cal Poly, Team S21-G1, Livingston Spring 2017 Miembro de Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
4 Miembros
14 Guías creadas
6 comentarios
I have this laptop. The top right corner of the keyboard has popped out. How do I fix this?
Michael Faherty - Contestar
Try removing the rubber foot under the popped corner, remove the screw, push down on the corner and replace the screw while holding the corner down.
Craig Carlson -
Just a note: the little rubber feet are all lettered (A-D) and you do need to match them to their proper corners when re-assembling.
Craig Carlson -
I have several keys that have stopped working. Replace the keyboard or is there a fix?
Richard Williams - Contestar
This happen when the ribbon cable that connects the keyboard gets squashed too hard.
See [1] below for a decription and fix.
[1] https://forums.lenovo.com/t5/Lenovo-Chro...
Jan -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 54
Todo El Tiempo: 13,736
