Saltar al contenido principal
Lenovo N21 Chromebook WiFi Card Replacement
Qué necesitas
  1. Lenovo N21 Chromebook WiFi Card Replacement, Keyboard and Trackpad Panel: paso 1, imagen 1 de 2 Lenovo N21 Chromebook WiFi Card Replacement, Keyboard and Trackpad Panel: paso 1, imagen 2 de 2
    • Power down the Chromebook before starting any repair.
    • Opening up your Chromebook voids the manufacturer warranty.
    • Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
  2. Lenovo N21 Chromebook WiFi Card Replacement: paso 2, imagen 1 de 2 Lenovo N21 Chromebook WiFi Card Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
  3. Lenovo N21 Chromebook WiFi Card Replacement: paso 3, imagen 1 de 2 Lenovo N21 Chromebook WiFi Card Replacement: paso 3, imagen 2 de 2
    • Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
  4. Lenovo N21 Chromebook WiFi Card Replacement: paso 4, imagen 1 de 3 Lenovo N21 Chromebook WiFi Card Replacement: paso 4, imagen 2 de 3 Lenovo N21 Chromebook WiFi Card Replacement: paso 4, imagen 3 de 3
    • Flip the laptop over and open the screen.
    • Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
    • Once completely separated, do not immediately pull the panel completely away from the bottom housing. There are wires that are still connecting the panel to the rest of the internals of the Chromebook.
  5. Lenovo N21 Chromebook WiFi Card Replacement: paso 5, imagen 1 de 2 Lenovo N21 Chromebook WiFi Card Replacement: paso 5, imagen 2 de 2
    • Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  6. Lenovo N21 Chromebook WiFi Card Replacement: paso 6, imagen 1 de 3 Lenovo N21 Chromebook WiFi Card Replacement: paso 6, imagen 2 de 3 Lenovo N21 Chromebook WiFi Card Replacement: paso 6, imagen 3 de 3
    • Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  7. Lenovo N21 Chromebook WiFi Card Replacement: paso 7, imagen 1 de 1
    • Remove the keyboard and trackpad panel away from the device.
  8. Lenovo N21 Chromebook WiFi Card Replacement, WiFi Card: paso 8, imagen 1 de 2 Lenovo N21 Chromebook WiFi Card Replacement, WiFi Card: paso 8, imagen 2 de 2
    • Use a screwdriver to remove the single 3mm Phillips screw that is holding the WiFi card in place.
  9. Lenovo N21 Chromebook WiFi Card Replacement: paso 9, imagen 1 de 2 Lenovo N21 Chromebook WiFi Card Replacement: paso 9, imagen 2 de 2
    • Remove the black and white wires attached to WiFi card by gently lifting them upwards.
    • When re-attaching the wires, make sure they are in the correct placement. You do not want to switch the black and white wires.
  10. Lenovo N21 Chromebook WiFi Card Replacement: paso 10, imagen 1 de 2 Lenovo N21 Chromebook WiFi Card Replacement: paso 10, imagen 2 de 2
    • Remove the WiFi card by pulling it straight out of its connector.
    • Keep the WiFi card horizontal and pull straight back to avoid causing the part harm.
Conclusión
7 personas más completaron esta guía.
Alex Cass
Miembro Desde 04/26/17
285 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S21-G2, Livingston Spring 2017 Miembro de Cal Poly, Team S21-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G2
Miembros de 4
12 Guías creadas
5 comentarios
Very nicely written. Pictures are helpful too.
Adil M. - Contestar
Thank you for this!
I had a Lenovo N21 Chromebook and the wifi card seemed to be faulty, but all it needed was a wipe off and It works perfectly now!
Evergreen - Contestar
My Lenovo N21 was dropping the wifi connection. It did it a year ago and then improved, but the past month started doing it again very bad to the point I started looking for a replacement. It would maintain the connection for 5 minutes to 1 hour. I searched the problem, found this advise, and in 10 minutes it is fixed and has not dropped in 2 days. I assume it is fixed for good. Thanks for the tip and excellent instructions. Saved me $300 also.
Kerry Dalton - Contestar
Kerry Dalton - what did you do to fix your problem? Replace? B & W wires crossed?
Im getting ready to take this device apart.
ssdrtelcom@gmail.com
Skip Stringham - Contestar
I’ve replaced network cards in laptops before, so I’m not totally new at this, but from your diagram, my Lenovo 100e looks TOTALLY different. Has anyone had this issue? I can’t seem to find my network card. Or, is it integrated??
Eric R. Klingsten - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 37
Todo El Tiempo: 3,824
