Saltar al contenido principal
Lenovo N20p Chromebook Keyboard Replacement
Qué necesitas
  1. Lenovo N20p Chromebook Keyboard Replacement, Keyboard: paso 1, imagen 1 de 2 Lenovo N20p Chromebook Keyboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook Keyboard Replacement: paso 2, imagen 1 de 2 Lenovo N20p Chromebook Keyboard Replacement: paso 2, imagen 2 de 2
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook Keyboard Replacement: paso 3, imagen 1 de 3 Lenovo N20p Chromebook Keyboard Replacement: paso 3, imagen 2 de 3 Lenovo N20p Chromebook Keyboard Replacement: paso 3, imagen 3 de 3
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
Conclusión
Shihao Cao
Miembro Desde 07/12/18
497 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G2, Cardinal Summer 2018 Miembro de UW Tacoma, Team S1-G2, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G2
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 269
