Saltar al contenido principal
Lenovo Miix 2 Vibrating Cable Replacement
Qué necesitas
  1. Lenovo Miix 2 Vibrating Cable Replacement, Battery: paso 1, imagen 1 de 2 Lenovo Miix 2 Vibrating Cable Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Vibrating Cable Replacement: paso 2, imagen 1 de 2 Lenovo Miix 2 Vibrating Cable Replacement: paso 2, imagen 2 de 2
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Vibrating Cable Replacement: paso 3, imagen 1 de 2 Lenovo Miix 2 Vibrating Cable Replacement: paso 3, imagen 2 de 2
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Vibrating Cable Replacement: paso 4, imagen 1 de 2 Lenovo Miix 2 Vibrating Cable Replacement: paso 4, imagen 2 de 2
    • Remove the battery by prying up with your fingers or a plastic opening tool.
  5. Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: paso 5, imagen 1 de 3 Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: paso 5, imagen 2 de 3 Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the vibrator cable which is connected with a white connector head to the motherboard, by gently lifting on the connector head with tweezers.
    • Remove the vibrator head by following the black and wire cable from the motherboard to where the head is located.
Conclusión
Max Rozema
Miembro Desde 04/02/19
157 Reputación
2 Guías creadas
Equipo
IUPUI, Team S3-G1, Harley Spring 2019 Miembro de IUPUI, Team S3-G1, Harley Spring 2019
IUPUI-HARLEY-S19S3G1
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 202
