Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
After removing the back case and battery, the motherboard is easy to remove from the Miix 2.
  1. Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps. You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver. Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard. Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Remove the battery by prying up with your fingers or a plastic opening tool. Remove the battery by prying up with your fingers or a plastic opening tool.
    • Remove the battery by prying up with your fingers or a plastic opening tool.
  5. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  6. Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force. To properly remove the speakers from the casing, push gently left until it shifts, then pull directly up.
    • Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force.
    • To properly remove the speakers from the casing, push gently left until it shifts, then pull directly up.
  7. Locate the LCD cable connector and gently pry it directly up with a spudger. Locate the LCD cable connector and gently pry it directly up with a spudger.
    • Locate the LCD cable connector and gently pry it directly up with a spudger.
  8. Remove the 5 ribbon cables. use the tip of the spudger to flip up the retaining flap, making sure to lift on the hinge and not the connector itself, then remove the cable from the connector. The flaps and connectors vary in color. Once the hinge has been lifted, the ribbon cable should take no force to remove.
    • Remove the 5 ribbon cables. use the tip of the spudger to flip up the retaining flap, making sure to lift on the hinge and not the connector itself, then remove the cable from the connector.
    • The flaps and connectors vary in color.
    • Once the hinge has been lifted, the ribbon cable should take no force to remove.
  9. Remove the 3 antenna cables using the tweezers by slowly pulling up. We found that pulling up and twisting a bit works best.
    • Remove the 3 antenna cables using the tweezers by slowly pulling up.
    • We found that pulling up and twisting a bit works best.
  10. Remove the 4 1.6mm screws with a J0 head. Remove the 4 1.6mm screws with a J0 head.
    • Remove the 4 1.6mm screws with a J0 head.
  11. Remove the red and black cable using the tweezers by gently pulling the connector to the right. Remove the red and black cable using the tweezers by gently pulling the connector to the right.
    • Remove the red and black cable using the tweezers by gently pulling the connector to the right.
  12. Lift the motherboard out of the tablet's case.
    • Lift the motherboard out of the tablet's case.
Conclusión
4 personas más completaron esta guía.
Diana Chiu
Miembro Desde 14/07/14
654 Reputación
4 Guías creadas
Equipo
Kid fixers Miembro de Kid fixers
Community
108 Miembros
68 Guías creadas
Do i need to update the BIOS once i have done this?
Do i also need to update the serial number of the machine?
dennis bortolin - Contestar
No, you should not have to upflash the BIOS and re-tattoo the machine - Assuming your replacement board has the proper OS entitlements already tattooed onto the UEFI , it should be picked up by the OS (Windows 10, I hope) and automatically re-activated. In fact, I imaged a Miix 2 8 out using a bootable USB drive + Clonezilla, and was able to image it into a new board and have everything re-activate just fine.
Kevin Kwan -
Is the micro usb port detachable? It seems soldered on from the pictures. I'm having trouble with the port. It charges the device but when I add an OTG cable the device dosnt power the USB and it dosnt detect it. Tried with a keyboard too, no response.
Dave - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 21
Todo El Tiempo: 3,744
