Saltar al contenido principal
Lenovo Miix 2 Battery Replacement
Qué necesitas
  1. Lenovo Miix 2 Battery Replacement, Battery: paso 1, imagen 1 de 2 Lenovo Miix 2 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Battery Replacement: paso 2, imagen 1 de 2 Lenovo Miix 2 Battery Replacement: paso 2, imagen 2 de 2
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Battery Replacement: paso 3, imagen 1 de 2 Lenovo Miix 2 Battery Replacement: paso 3, imagen 2 de 2
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Battery Replacement: paso 4, imagen 1 de 2 Lenovo Miix 2 Battery Replacement: paso 4, imagen 2 de 2
    • Remove the battery by prying up with your fingers or a plastic opening tool.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 5-8, Maness Spring 2015 Miembro de Cal Poly, Team 5-8, Maness Spring 2015
CPSU-MANESS-S15S5G8
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 35
Todo El Tiempo: 8,913
