Saltar al contenido principal
Lenovo Legion Y530-15ICH Speaker Replacement
Qué necesitas
  1. Lenovo Legion Y530-15ICH Speaker  Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Speaker  Replacement: paso 2, imagen 1 de 2 Lenovo Legion Y530-15ICH Speaker  Replacement: paso 2, imagen 2 de 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Speaker  Replacement, Battery: paso 3, imagen 1 de 1
    • Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
  4. Lenovo Legion Y530-15ICH Speaker  Replacement: paso 4, imagen 1 de 2 Lenovo Legion Y530-15ICH Speaker  Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Now you can safely remove the battery.
  5. Lenovo Legion Y530-15ICH Speaker  Replacement, Speaker: paso 5, imagen 1 de 1
    • Remove the five screws using the Phillips #0 screwdriver.
  6. Lenovo Legion Y530-15ICH Speaker  Replacement: paso 6, imagen 1 de 1
    • Gently peel up the copper adhesive.
  7. Lenovo Legion Y530-15ICH Speaker  Replacement: paso 7, imagen 1 de 1
    • Remove the speakers from the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 48
Todo El Tiempo: 1,375
