Saltar al contenido principal
Lenovo Legion Y530-15ICH Solid State Drive Replacement
Qué necesitas
  1. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Solid State Drive Replacement: paso 2, imagen 1 de 2 Lenovo Legion Y530-15ICH Solid State Drive Replacement: paso 2, imagen 2 de 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: paso 3, imagen 1 de 2 Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: paso 3, imagen 2 de 2
    • Do not remove the thermal pad.
    • Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
  4. Lenovo Legion Y530-15ICH Solid State Drive Replacement: paso 4, imagen 1 de 2 Lenovo Legion Y530-15ICH Solid State Drive Replacement: paso 4, imagen 2 de 2
    • Carefully remove the SSD from its connector.
Conclusión
Insert your new SSD into the connector. To reassemble your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S7-G1, Regan Winter 2020 Miembro de Cal Poly, Team S7-G1, Regan Winter 2020
CPSU-REGAN-W20S7G1
Miembros de 4
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 33
Todo El Tiempo: 5,535
