Saltar al contenido principal
Lenovo Legion Y530-15ICH RAM Replacement
Qué necesitas
  1. Lenovo Legion Y530-15ICH RAM Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH RAM Replacement: paso 2, imagen 1 de 2 Lenovo Legion Y530-15ICH RAM Replacement: paso 2, imagen 2 de 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH RAM Replacement, RAM: paso 3, imagen 1 de 2 Lenovo Legion Y530-15ICH RAM Replacement, RAM: paso 3, imagen 2 de 2
    • Use the plastic opening tool to unlatch the metal cover that secures the RAM housing.
    • Ensure that the opening tool is only hooked on the metal housing.
  4. Lenovo Legion Y530-15ICH RAM Replacement: paso 4, imagen 1 de 3 Lenovo Legion Y530-15ICH RAM Replacement: paso 4, imagen 2 de 3 Lenovo Legion Y530-15ICH RAM Replacement: paso 4, imagen 3 de 3
    • Push the metal tabs inwards to release the RAM.
    • After the clips are removed, the RAM will push up at an angle.
    • Remove the RAM from the device.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team S7-G1, Regan Winter 2020 Miembro de Cal Poly, Team S7-G1, Regan Winter 2020
CPSU-REGAN-W20S7G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 26
Ultimos 30 días: 61
Todo El Tiempo: 4,115
