Introducción
This guide will show you how to properly replace the keys on your keyboard. The keys may need replaced on your keyboard if they are sticky, broken or dont properly regeister to your device.
Partes
No se requieren partes.
  1. Carefully remove the broken key(s). Use the flat end of the spudger to gently pop the key off. When removing the key(s) be very cautious not to remove the white plastic pieces underneath with it. When reinstalling key, no spudger is needed. Just pop it into place with fingers.
    • Carefully remove the broken key(s). Use the flat end of the spudger to gently pop the key off.
    • When removing the key(s) be very cautious not to remove the white plastic pieces underneath with it.
    • When reinstalling key, no spudger is needed. Just pop it into place with fingers.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Using the flat end of the spudger, very carefully lift up the corners of the white plastic piece. Do not disconnect the two. With the help of tweezers (needle nose works best), pull the connected plastic pieces out.
    • Using the flat end of the spudger, very carefully lift up the corners of the white plastic piece. Do not disconnect the two.
    • With the help of tweezers (needle nose works best), pull the connected plastic pieces out.
    • If the two plastic pieces come apart refer to the last picture, showing the orientation in which they should be connected.
    • For reinstallation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Conclusión
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 15
Últimos 30 Días: 81
Todo El Tiempo: 239
