Saltar al contenido principal
Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement
Qué necesitas
  1. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: paso 1, imagen 1 de 3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: paso 1, imagen 2 de 3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: paso 1, imagen 3 de 3
    • Carefully remove the broken key(s). Use the flat end of the spudger to gently pop the key off.
    • When removing the key(s) be very cautious not to remove the white plastic pieces underneath with it.
    • When reinstalling key, no spudger is needed. Just pop it into place with fingers.
  2. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: paso 2, imagen 1 de 2 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: paso 2, imagen 2 de 2
    • Using the flat end of the spudger, very carefully lift up the corners of the white plastic piece. Do not disconnect the two.
    • With the help of tweezers (needle nose works best), pull the connected plastic pieces out.
    • If the two plastic pieces come apart refer to the last picture, showing the orientation in which they should be connected.
    • For reinstallation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Conclusión
3 comentarios
This is only for the key caps, what about the keyboard itself?
Rick Montoya - Contestar
I agree the video is mislabeled. You are not replacing the board just keys.
Pat Schutte - Contestar
Please create a tutorial for keys with stabilizer like space bar and enter keys.
Affix - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 30
Ultimos 30 días: 176
Todo El Tiempo: 10,122
